tv_loadImage does not load psd-file
kaspar128
Post by kaspar128 »
Hi everyone,
It is really cool that tvpaint can import a photoshop-file. However, I cannot find a way to do that with a george-command:
tv_loadImage "psdfile.psd"
tv_loadsequence "psdfile.psd"
..both result in an error.
Is there a possible method for importing psd's through George?
I checked above with a png-version, which loaded just fine. So the quoting is not the issue here..
Thanks in advance! :D
NathanOtano
Re: tv_loadImage does not load psd-file
Post by NathanOtano »
I also need this feature! :)
Xavier
Post by Xavier »
kaspar128 wrote: 08 Jul 2021, 15:17 However, I cannot find a way to do that with a george-command:
Hi Kaspar, sorry for the delay. Actually, it is managed in the code so it should work ... so it's probably a bug :?
I moved your topic into the technical support section.
Could you please tell us about your configuration ?
And if possible, provide a sample PSD file to help us reproducing the bug ?
Thanks
