disable right click erase option
Joost
Post by Joost »
Hi there,
Is there a way to disable the right click erase function?
I'm constantly erasing lines by accident.
Thanks in advance!
TVP Pro 11.7.1
Re: disable right click erase option
You could, in Edit>preferences>General
at Tablet, switch off wintab and set it to Ink
Or you could opt to disable rightclick in the Wacom Tablet Properties
by changing the front rockerswitch from "Right Click" to something else...
Joost
Post by Joost »
Thanks for your reaction Peter!
However: I don't see the options you are describing in the preferences.
I only see this
Screenshot 2021-07-09 at 13.47.21.png (30.6 KiB) Viewed 6291 times
And I can't change it in the Wacom settings, since I need the right click for a lot of things in TVP :)
TVP Pro 11.7.1
Joost wrote: 09 Jul 2021, 13:53 And I can't change it in the Wacom settings, since I need the right click for a lot of things in TVP :)
Ha yes i figured that was probably not an option.
Joost wrote: 09 Jul 2021, 13:53 However: I don't see the options you are describing in the preferences.
oops... taht is possible, our production is currently working in 11.0.8 i didn't realise that this function had changed in 1.5...
but those Tablet options don't do anything with regard to erasing?
Xavier
Post by Xavier »
Peter Wassink wrote: 09 Jul 2021, 14:13
Not, the Wintab options were not modified...
Joost wrote: 09 Jul 2021, 12:24 Is there a way to disable the right click erase function?
But which action is configured in your driver settings for the right click ?
Otherwise, you can also uncheck both options in the preferences :
Capture d’écran_2021-07-09_14-29-47.png (5.01 KiB) Viewed 6270 times
Joost
Post by Joost »
Hi Xavier,
I didn't configure any setting for my right click button. It's just "right click".
I have unchecked both boxes, but the erase function is still there... Is this a bug then?
TVP Pro 11.7.1
