Hello there. I have been editing some old TVP files. I use to use TVP10, and these files were alone. But now with TVP11.5, I see that every time I make or edit a file, other sub-files start appearing in the same folder. My biggest problem is that these are sometimes bigger than the actual .tvpp file... and some of the files I work on are multiple GBs in size! I'm afraid I'll get to the limits of my drive...
Is it safe to delete these?
https://gyazo.com/c55250b4ae0a86c666e94503fc387fdf
What are these numbered Temp files? Topic is solved
Re: What are these numbered Temp files?
Those are multi-backup files : https://www.tvpaint.com/doc/tvp11/index ... ences-save
Thank you! I assume that means I can delete them once the project is finished..
- schwarzgrau
Yea, you can. I let TVPaint save them to a folder just for these type of files and delete all files in this folder from time to time
