my problem is rather trivial: I have a gap between the legs of my character and want the paint roll tool to leave that out.
The space between the legs should not be filled, it should remain alpha only.
But I can either take away all the fill or I will have the gap filled as well.
Help please!
Colo & Texture Layer Alpha
Re: Colo & Texture Layer Alpha
an image would help us help you.
Strange, my browser shows the image...
The image is not showing up on my end , either.
Here is a screenshot showing what I see:
To attach an image to your post, use the Attachments tab and click Add Files. Upload your image file, then to have it
appear in the body of your post click on 'Place Inline' .
OR if it is an image source on the web use the Insert Image tags in the posting toolbar :
when you click on the CTG layer's little palette symbol in the layer panel, you'll see that in the appearing "edit colors "panel is, additional to the colors that you picked so far, a field (by default with a turquoise square) which says "Exclusion". You can use it with the CTG pen tool on gaps like the one in your image, and it will exclude the area from the paint surrounding it.
Yiynova MSP19U
TvPaint Animation 11.0.6 Pro
Yiynova MSP19U
If it's overfilling like that , use an Exclusion squiggle to keep that area between the legs from being filled.
(click image to view it larger)
Thanks a lot, that was it!
