my problem is rather trivial: I have a gap between the legs of my character and want the paint roll tool to leave that out.
The space between the legs should not be filled, it should remain alpha only.
But I can either take away all the fill or I will have the gap filled as well.
To attach an image to your post, use the Attachments tab and click Add Files. Upload your image file, then to have it
appear in the body of your post click on 'Place Inline' .
Screen Shot 2021-10-04 at 7.52.02 AM.jpg (38.74 KiB) Viewed 8461 times
OR if it is an image source on the web use the Insert Image tags in the posting toolbar :
Screen Shot 2021-10-04 at 7.55.48 AM.jpg (15.17 KiB) Viewed 8461 times
when you click on the CTG layer's little palette symbol in the layer panel, you'll see that in the appearing "edit colors "panel is, additional to the colors that you picked so far, a field (by default with a turquoise square) which says "Exclusion". You can use it with the CTG pen tool on gaps like the one in your image, and it will exclude the area from the paint surrounding it.
Yiynova MSP19U
TvPaint Animation 11.0.6 Pro
