Big problem about layer with REPEAT IMAGES exporting to AfterEffect
Zane
Post by Zane »
Hello, has anyone tried to export your project that has some repeat images layer to AfterEffect? I notice that the repeating just disappears after I export to AfterEffect. When I import my json file into AfterEffect the repeating part just stucks. I even tried to switch the Sequence Import Mode between Rebuilt and Native, but there's no repeating at all. So is it telling me that I should transform all of the repeating part to actual frames before I export to AfterEffect?
Tylos
Re: Big problem about layer with REPEAT IMAGES exporting to AfterEffect
Post by Tylos »
Yes, AF Exporter/Importer has some problems. I hope they will fix that in future... I usuali fix that manualy by coping frames in time line....
schwarzgrau
Post by schwarzgrau »
I encountered the same problem and it seems you need to convert them to "real" frames before using the export to AE. That's the reason I made this script here.
Of course it's only a stupid workaround, till it's fixed, but better than nothing.
Zane
Post by Zane »
schwarzgrau wrote: 31 Jan 2022, 11:31 I encountered the same problem and it seems you need to convert them to "real" frames before using the export to AE. That's the reason I made this script here.
OMG this is really helpful!! Great script !! Thanks!!
