Is it my Wacom pen or?...
Joost
Post by Joost »
Since I updated to TVP 11.5.3 it seems like trying to move layers in the timeline is much harder.
It always grabs the small squares in the corner of each frame, in stead of moving the layer through the timeline. I almost lost many frames because of this situation, thinking I moved a layer but accidentally removing a lot of frames by grabbing the small queer in the upper left corner of a frame in the layer window...
Has something been changed, or is my Wacom pen just a bit off?
TVP Pro 11.7.1
Xavier
Re: Is it my Wacom pen or?...
Post by Xavier »
A change made on purpose with the 11.5.3, to answer this request : viewtopic.php?f=10&t=12353&p=126395
Yet it's possible that it introduced a side effect.
Could you please post a screen recording, or at least show me where it happens on a screen capture ?
Joost
Post by Joost »
Here is my screen recording. I tried to move the layers three times, only the second time I succeeded. And it's very easy to accidentally delete the frames...😱
ScreenRecording.mov
(4.03 MiB) Downloaded 368 times
TVP Pro 11.7.1
Xavier
Post by Xavier »
Joost wrote: 01 Feb 2022, 12:00 Here is my screen recording. I tried to move the layers three times, only the second time I succeeded. And it's very easy to accidentally delete the frames...😱
Thanks for the recording. Have you tried changing your layer zoom level ? Click on the lens button and mouve your mouse :
Capture d’écran_2022-02-01_13-40-05.png (22.38 KiB) Viewed 4018 times
Also watch when you click : when grabbed, the handle should change color.
Apart from that, you're right it seems that the handle area is a little too wide. I'll reduce it.
Joost
Post by Joost »
Yes, even when fully zoomed in, I really have a hard time grabbing the layer to be able to move it.
I have to click multiple tomes, to not accidentally pick the checkbox.
I see why you have changed it, but in my opinion it's too risky now... Did no-one else notice this?
TVP Pro 11.7.1
Xavier
Post by Xavier »
Joost wrote: 01 Feb 2022, 15:40 Yes, even when fully zoomed in, I really have a hard time grabbing the layer to be able to move it.
I wouldn't say risky. Maybe you also have a sensivity issue with your stylus ?
I reproduced it with a mouse : it occurs when you click on the right border, which is also the left border of the next instance. So far, using a mouse, I'd say I fixed it (in the next version to come).
Joost
Post by Joost »
Wow thanks! that's fast!
For now I just will take extra care where I will click :)
TVP Pro 11.7.1
Xavier
Post by Xavier »
Joost wrote: 01 Feb 2022, 17:42 Wow thanks! that's fast!
It was a small bug, on a part of code I already know. You're welcome :)
