Pen pressure glitch with some brushes
Can anyone explain to me why this is happening with my brush pressure?
I notice brushes with a wide range of sensitivity from low to high sometime place a spot before the stroke when I press soft and gradually press harder.
- Untitled_(1)Crop.gif (84.19 KiB) Viewed 6940 times
--SPECS--
Windows 11
AMD RX 580 (8GB)
AMD Threadripper 3970x (32 core)
112GB Ram
TVP 11.5.3
XP-Pen Artist 24 pro
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Re: Pen pressure glitch with some brushes
Hello Ross, are those custom made brushes?
If that's the case, could you post them or send them to me, please?
Which OS and which version of TVPaint please ?
Windows 11.
TV paint 11.5.3 64 bits
Brushes can be downloaded here:
https://www.dropbox.com/s/vkqayh9g5ugih ... r.rar?dl=0
--SPECS--
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Hello, no issue on my part, great brushes by the way. In the TVPaint preferences, I have the drawing mode set to Wintab with Subpixel disabled, what about you?
Same here.
What I have also noticed is that the issue only comes when the Power(brush settings) is set to constant.
--SPECS--
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Hello again, no issue for me when setting the Power variable to "constant". Does this happen only with one brush in particular of all the one you uploaded?
Also, which tablet model are you currently using?
We have seen that with old versions of the tablet driver. Which drawing device do you use ?Ross wrote: ↑17 Mar 2022, 06:32 Windows 11.
I am using an Ugee 2150.
I will acknowledge that Ugee seems to have stopped updating the drivers for this device.
--SPECS--
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Sadly, to this day I have never managed to reach Ugee's customer support. Another user had a similar issue with one of their models and couldn't get a response on his part either.
I have these brushes, too. I can't reproduce the odd behavior you're experiencing on my end.Ross wrote: ↑17 Mar 2022, 06:32 Windows 11.
Yeah, might be their drivers but my xppen is on its way so no worries!
--SPECS--
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
Windows 11
AMD RX 580 (8GB)
112GB Ram
TVP 11.5.3
I get this issue as well when my eraser brush power on constant. You were the first person to replicate my issue, but I get this on a Intuos Pro with updated drivers
Does this happen after switching to the TVPaint window from another application or does this happen randomly?
