pixelated lines
pixelated lines
Hi I'm quite new to tv paint, I have been animating a video using the air brush, with an aspect of 100 and size 8, and I've been noticing that although the brush is usually drawing the way I want, sometimes i find that even after exporting, the line is very pixelated. I suspect that it may have something to do with drawing on a rotated canvas, but i'm not sure why that would be the case, or how to work around it. Any ideas? ...My project is 1920 X 1080, i have attached an image showing the pixelating in the line, its cropped from an exported png file. Thank you !!
- Screen Shot 2014-10-29 at 11.57.50 pm.png (21.47 KiB) Viewed 22394 times
Re: pixelated lines
hello fm, and welcome,
what's your tvpa version, and what OS are you using ?
did you color-fill the character on the same (line)layer, or on a separated color layer ?
if the color is separated (recommanded imo), can you crop the "line only" of your drawing,
to see who's the culprit ...
btw, why don't you use a pen brush instead than a "tiny" airbrush ?
airbrush at very small size isn't as smooth as a that ...
I think a pen brush with the right settings (AA = on) would do the job probably with a better quality.
Re: pixelated lines
thank you! I am using TV Paint 10.5, OSX 10.9.4... I will definitely be colouring on a separate layer from now on! I prefer the varied weight of the tiny air brush... and find that even when I use a pen tool the pixelating is still happening. I have attached an image showing the pixelating on just the line, with both pen (with AA = on) and airbrush (with the settings I have been using).
- Screen Shot 2014-10-30 at 10.52.17 am.png (109.83 KiB) Viewed 22353 times
Re: pixelated lines
is your project maybe set to field: upper/lower ?
It should always be set to Progressive
Re: pixelated lines
Peter beat me to it. I was going to say the same thing .Peter Wassink wrote:is your project maybe set to field: upper/lower ?
In the Startup Panel, make sure that Field is set to Progressive . (not upper first or lower first)
Re: pixelated lines
Hi thanks yes it is already set to progressive.
Re: pixelated lines
what was your pen settings ? ... and how much your grabbed view is zoomed in your picture ?
I mean the "pixilating" lines could be on the screen (specially when the preview isn't exactly at 100%, or rotated),
but not in the exported file .
btw, why do you activate the smoothing feature, but with a "0" amount ...?
if you don't want any line smoothing, it would be better to check it OFF.
Re: pixelated lines
Hi, I'm having the same problem in TV Paint 11 with a Mac OS 10.14.2. I also have it set to "progressive", here is a JPG I exported to show that it exports pixelated as well.
Re: pixelated lines
Hello ! Ijust found a solution to this issue and wanted to share, try to go to 'window' >> 'settings' >> 'shape settings' and increase smoothing number. For me it was 2 and I pushed it up to 15 and it works just fine
