Missing shortcut for Reverse Selected Images
Soom
Post by Soom »
No shortcut for Reverse Selected Images
please add, thanks
https://vimeo.com/danas
Re: Missing shortcut for Reverse Selected Images
It's in Shortcuts > Layer > Reverse Selection .
For clarity the shortcut Reverse Selection should be named Reverse Selected Images to match the command from the layer menu , but it does the same thing.
Screen Shot 2022-05-27 at 5.01.28 PM.jpg (13.07 KiB) Viewed 2591 times
Screen Shot 2022-05-27 at 3.51.34 PM.jpg (87.53 KiB) Viewed 2591 times
Xavier
Post by Xavier »
D.T. Nethery wrote: 27 May 2022, 23:34 For clarity the shortcut Reverse Selection should be named Reverse Selected Images to match the command from the layer menu , but it does the same thing.
You're right, I changed the name ;)
Soom
Post by Soom »
ahhh, ok, so it was a name mismatch. thanks!
