Sierra 10.12.6 + Latest TVpaint = LOVE ?! Topic is solved
Animationriver
Post by Animationriver »
Hello, TVPaint developers!
I am working on Macbook OS Sierra 10.12.6
I want to install the latest TVPAINT animation software.
My Question:
I can stay on Sierra 10.12.6. ?
Sierra 10.12.6 + Latest :D TVpaint = LOVE ?!
Or do I need to upgrade?
What is the oldest version of mac os that works well with the latest TVPaint software?
:D
Xavier
Re: Sierra 10.12.6 + Latest TVpaint = LOVE ?!
Post by Xavier »
Which licensing system do you imply ? is it Safenet or Wibu ?
Animationriver
Xavier wrote: 01 Jun 2022, 15:25 Which licensing system do you imply ? is it Safenet or Wibu ?
I don't know these systems.
I specified the possibility of work without failures. I asked a user level question. :D
Hello, what Xavier asked is: does your license come with a USB dongle or is it dematerialized?
Hironori Takagi
Post by Hironori Takagi »
Hello, Animationriver.
I think connecting to the internet can be a challenge in your country.
I'm glad to be able to confirm that I'm continuing to produce works safely.
I'm sorry to send you a message different from the question.
Animationriver
Dean wrote: 02 Jun 2022, 09:23 Hello, what Xavier asked is: does your license come with a USB dongle or is it dematerialized?
Hello.
Now I understand.
My license with usb key. :D
Well, using a version earlier than Sierra might cause issues. The only prequisite for using TVPaint on these systems with a Sentinel dongle is to make sure to use the correct Sentinel driver version.
Animationriver
Dean wrote: 03 Jun 2022, 14:38 Well, using a version earlier than Sierra might cause issues. The only prequisite for using TVPaint on these systems with a Sentinel dongle is to make sure to use the correct Sentinel driver version.
Big thanks! :D
Hironori Takagi
I understood your working environment with your PM.
I think using the WIBU system virtual dongle is risky in your country.
Also, I think it will take time to have the WIBU hardware key delivered from TVPaint support.
I recommend using TVPaint 11.0.10 for the time being with the Safenet USB key as it's not the latest Mac OS you're using,
but it also has the benefits of 11.5.x, so it's the latest TVPaint. If you want to use, I recommend you to talk to Dean.
