How to exit param single Topic is solved
TheInsaneum
Post by TheInsaneum »
Hi, I just wrote a tiny script to offset the paper in TVP since there dosent seem to be a standard way to do it. (let me know if I just missed it)
But I dont fully understand how to propperly exit the george program from using "PARAM Single".
This is the code Im running:
PARAM Single
parse result s x y m
tv_paper OffsetX x OffsetY y
EXIT
Everything is working as I wanted but the cross curser that is used to initiate the program stays and runns the program again every time I click on screen. The only way I found to stop the script from executing is by hitting ESC. I thaught using "EXIT" in the script would exit the script and the curser would return to whatever tool I was using before but it dosent. Is there a way to exit the script or do I need to hit ESC every time I use it?
Btw. Im using TVP11.5.3 on Win10 on a mobilestudio if that changes anything.
Re: How to exit param single
Add this line in place of the EXIT:
tv_SetActiveShape FreeHandLine
sven
