Remote Control Bar Topic is solved
cf-mankit
Remote Control Bar
Post by cf-mankit »
Hello TVPainters,
How do I put back the remote control bar above the Timeline. It's gone all of a sudden.
If I use Room 3 which has the remote panel as a strip above the timeline, the canvas does not scale larger when I hide the timeline like Room 1.
Thank you
Re: Remote Control Bar
Hello, this button is used to hide the remote:
A video of this issue happening could help if you have the time :)
cf-mankit
Post by cf-mankit »
Hi Dean thank you for your response~! I am aware of that button.
Trying to figure out how I can get you a video, but if you take a look at this screen shot I don't have that button. I think it's something with the canvas setting.
( Screen shot preview doesn't seem to preview, I'll attach also )
Thank you
Try pressing V - in default config this should toggle the view (or once it was so).
It does appear as if your interface is stuck in Inlay View. As of version 11.5.3 I don't believe that Inlay View has a default keyboard shortcut assigned to it , but you may have unintentionally selected Inlay View under the View Menu. Deselect Inlay View from the View Menu to get back to normal.
Screen Shot 2022-07-10 at 1.53.05 PM.png (91.35 KiB) Viewed 5483 times
If you wanted to assign a keyboard shortcut to it , go to Shortcuts > Interface > Inlay View and assign an available key to it.
Screen Shot 2022-07-10 at 1.50.54 PM.png (86.73 KiB) Viewed 5483 times
cf-mankit
Post by cf-mankit »
Thank you everyone~
