Warp Tool not visible
LinkSlayer
Post by LinkSlayer »
Is the Warp Tool (not Warp Grid, under FX Stack) obsolete?
I've seen tutorials that show it under Panning, Transform and Perspective in the Main Panel, and I don't see it there...
TVP Animation 11 WIBU (11.5.3-64 bits)
Standard Edition
Windows 10
Re: Warp Tool not visible
At the least, there is a need to know which version of TVPaint are you using? See the following post...New users seeking Help
sven
LinkSlayer
Ah yes, thanks! Windows 10, TVPaint 11.5.3-64 bits, Standard Edition.
Standard Edition
Windows 10
This is where the Warp Tool is located in version 11.5.3 -
Here are some interesting custom tools to use with the Warp Tool -
viewtopic.php?p=81202#p81202
LinkSlayer
Thanks, D.T.
That's where I thought it should be, but I don't have it:
Screenshot (122).png (28.18 KiB) Viewed 3552 times
Standard Edition
Windows 10
LinkSlayer
Problem solved - it's a Pro tool, but isn't greyed out like the others I've seen. Just doesn't appear at all.
Standard Edition
Windows 10
LinkSlayer
D.T. Nethery wrote: 03 Sep 2022, 18:28 Here are some interesting custom tools to use with the Warp Tool -
Those are awesome, D.T.!
Standard Edition
Windows 10
LinkSlayer wrote: 03 Sep 2022, 19:13 Those are awesome, D.T.!
The animation and the scripts are by Svengali.
LinkSlayer wrote: 03 Sep 2022, 19:12 Problem solved - it's a Pro tool, but isn't greyed out like the others I've seen. Just doesn't appear at all.
Oh, I didn't realize that it's a "Pro only" tool. You're right , usually those are visible (but greyed-out) in the interface.
