SELECT Empty Layer(s) in 11.7.0
Cardin
Post by Cardin »
There seems to be some inconsistency with how the software identifies an empty layer in 11.7.0
Problem 1:
Layer 1
A layer solely consisting of an EMPTY image set to an exposure greater than 1 is NOT identified as an empty layer. But if you break the extended image into separate empty images, it will be identified as an empty layer.
Click on image for the gif
Issue 2:
Layer 1's first image is empty but the second is not. Yet it is still identified as an Empty Layer.
***I suspect this is somehow related to the Delete Empty Layer bug that has already been confirmed here https://tvpaint.com/forum/viewtopic.php?t=15164
But I figured I would make a new post just in case it isn't. Apologies if any of this is redundant :oops:
Thanks, TVPaint team :)
TVPaint 12.0.0 Pro
Xavier
Re: SELECT Empty Layer(s) in 11.7.0
Post by Xavier »
Cardin wrote: 27 Sep 2022, 07:50
Thanks for your report, it is indeed the same issue and it will be fixed ASAP.
Hey Cardin,
We've addressed this issue in today's hotfix: https://forum.tvpaint.com/viewtopic.php ... 25#p130925 :)
