Color is not consistent when after using eraser, I don't know if anyone can recreate this consistently so here is a video showing the issue.
11.7.0 oct 6 hotfix
My eraser settings.
With more testing, this happens with all eraser settings in preferences
Color is not consistent when after using eraser 11.7
- obs64_MW5mmVWHGh.mp4
- (14.23 MiB) Downloaded 244 times
TVPaint 11.7.3, 12.0.1 Pro 64, Windows 10 H
i7-8700k, 48GB, RTX 2080 8G Desktop, Cintiq Pro 24 (3840x2160)
Ryzen 9 5900HS,16GB, RTX 3060 6G Laptop, Wacom ONE 13 Touch (1920x1080)
Re: Color is not consistent when after using eraser 11.7
I also noticed it reverts back to a previous color in history, It isn't exclusive to the previous color, so long as you have an exact color that was made before it will sometimes cause this bug.
- obs64_1OthrPuna6_Trim.mp4
- (1.46 MiB) Downloaded 245 times
This could not be reproduced here.TVPUSER wrote: ↑10 Oct 2022, 05:42 Color is not consistent when after using eraser, I don't know if anyone can recreate this consistently so here is a video showing the issue.
11.7.0 oct 6 hotfix
My eraser settings.
However I notice that you have both the eraser checkboxes unchecked in your settings, which means you have regular tools on both ends of your pen. We'd need to know which tool you have on the eraser.
Could you please also try resetting your Wacom settings ?
I've gone through all permutations of the checkboxes and this still happens every now and then. I've done what I can to reset my wacom settings also.. It still happens though getting it to reproduce 100% of the time is still something I haven't really figured out either.. it is still quite annoying..
Hi, does this only happen with the color panel in "Slider" mode?
It almost seems that TVPaint detects your stylus as 2 different ones with different tools memorized at each end, so weird!
