macOS Monterey / Ventura / Sonoma and TVPaint Animation 11 [UPDATE 02/10/2024]
David_Fine
Re: macOS Monterey and TVPaint Animation 11 [UPDATE 17/06/2022]
Post by David_Fine »
Matthieu wrote: 28 Oct 2022, 10:20 I have updated my iMac to Ventura for testing purposes
Please do let us know how it's running so far.
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
David_Fine
Still no word on MacOS Ventura? Would really appreciate knowing if TVPaint is running okay on it or not. Please and thank you!! :)
David Fine
Vancouver, Canada
Holger
Post by Holger »
I just updated to Monterey and since TVP had trouble with the dongle I found this thread. I have now downloaded TVP again and have trouble installing it. I get an error saying that Apple can't verify that the software is secure. I also tried this advice from Thierry on page 1 , but the link does not open for me: UPDATE 17/06/2022: On macOS Monterey 12.4 (the latest one), TVPaint doesn't start because CodeMeter doesn't seem to be working.
If you updated to macOS Monterey, please install this version of CodeMeter and the software should be able to run once again: https://owncloud.tvpaint.com/index.php/ ... Sf5Zgj85lF
Could I get some help, please. Thanks in advance.
Mac mini
Intel Core i7
3 GHz
16 GB
TVPaint 11.0.10 pro (mac-64)
Holger wrote: 12 Feb 2023, 02:45 I just updated to Monterey and since TVP had trouble with the dongle I found this thread. I have now downloaded TVP again and have trouble installing it. I get an error saying that Apple can't verify that the software is secure. I also tried this advice from Thierry on page 1 , but the link does not open for me: UPDATE 17/06/2022: On macOS Monterey 12.4 (the latest one), TVPaint doesn't start because CodeMeter doesn't seem to be working.
The latest version of Monterey is 12.6.3 (that's the one I have). I believe the Codemeter installer that is contained in the TVPaint 11.7.1 installer (released on Dec. 22, 2022) is the correct installer.
Make sure you have the Dec. 22,2022 release downloaded and reinstall Codemeter from that one, following these instructions for installation: viewtopic.php?t=14973
https://youtu.be/VjaiYmyVt2c
Screen Shot 2023-02-12 at 7.54.49 AM.png (14.43 KiB) Viewed 32396 times
If you continue to get that message from Apple about how the software can not be opened because it is from an "unidentified developer", do this:
In the Finder on your Mac, locate the app you want to open.
Don’t use Launchpad to do this. Launchpad doesn’t allow you to access the shortcut menu.
Control-click the app icon, then choose Open from the shortcut menu.
Click Open.
The app is saved as an exception to your security settings, and you can open it in the future by double-clicking it just as you can any registered app.
Note: You can also grant an exception for a blocked app by clicking the Open Anyway button in the General pane of Security & Privacy preferences. This button is available for about an hour after you try to open the app. To change these preferences on your Mac, choose Apple menu > System Preferences, click Security & Privacy , then click General.
https://support.apple.com/guide/mac-hel ... 0/mac/12.0
Holger
Post by Holger »
Thanks David! I re-installed from my account and have the Dec22, 20022 version. I also used the exception method with system preferences that you mentioned.
I'm back to the original problem with the dongle not getting seen by TVpaint. I'm using a USB dongle, it's plugged in and has a green LED light active, but in TVP I get this pop-up telling me to plug in the dongle. In the greyed out TVP window I can also see a tab called purchase, which makes me wonder if I should and where I could re-enter my unlock code.
I can wait until Monday and hopefully somebody from TVP could tell me how to proceed.
Mac mini
Intel Core i7
3 GHz
16 GB
Holger wrote: 12 Feb 2023, 19:31 Thanks David! I re-installed from my account and have the Dec22, 20022 version. I also used the exception method with system preferences that you mentioned.
The issue is that the company who make the dongle, Safenet , have not updated their dongle drivers to work with MacOS Monterey or Ventura. See: viewtopic.php?p=130648#p130648
So you need to request that TVPaint Support migrates your license to the WIBU dongleless security system. I would suggest you use the Contact form on the website as it will be more likely to be seen first thing on Monday.
https://tvpaint.odoo.com/en_US/contactus
Hello Holger, did you contact us via the form and did you receive a response? Otherwise please do not hesitate to send me a PM.
David_Fine wrote: 30 Oct 2022, 20:27
David_Fine wrote: 29 Nov 2022, 18:30 Still no word on MacOS Ventura? Would really appreciate knowing if TVPaint is running okay on it or not. Please and thank you!! :)
Bump.
Does TVPaint 11.7.1 run with no problems on MacOS Ventura ?
Hello David, no issue on Ventura so far.
Dean wrote: 14 Feb 2023, 10:29 Hello David, no issue on Ventura so far.
Thank you. I thought that was the case , but because David Fine's two inquiries above had not received a reply I wanted to confirm that TVPaint is running on MacOS Ventura.
rohandeshchougule
Post by rohandeshchougule »
Hello! As Dean has already replied but I was just wondering if TVP 11.7 or 11.7.1 works as it should on the latest MacOS Ventura 13.2.1?
Hello, yes as I posted above, no issue so far.
Maybe I didn't understand your question.
rohandeshchougule
Hello! Thanks for the reply, sorry for the confusion, I meant to ask if it works normally on this specific version of Ventura 13.2.1
Matthieu
Post by Matthieu »
Hello!
I confirm TVPaint 11.7.1 works with Ventura 13.2.1. You should be able to update without any issues.
rohandeshchougule
Thank you for your response. 🙏🏼
