Hi, Joe -
(and anyone else following this discussion)
Re: Batch Renaming of Clips -
Well, how embarrassing is this for me ? (I must be getting old !
) . After some poking around in old posts on this forum I am reminded that back in 2011 a TVPaint user named Mads Juul posted his custom script panel for
Batch Renaming Clips. I believe I had downloaded Mads' script at one time , but apparently I totally forgot about it ! DOH! But in my defense, in the past I haven't done much in the way of batch renaming of clips because I haven't had a great need for it. I usually work on individual animation scenes in TVPaint, not storyboards/animatics . But our recent conversation has reminded me that the Clip naming convention when splitting a long project into smaller clips really needs a batch renamer . And now I have remembered it already exists ! (I confirm it still works in TVPaint 11.7.1)
Mads' script is posted here:
viewtopic.php?f=11&t=5403&p=47609
At the time Mads and several others mentioned:
"this batch renaming of clips function really should be built-in to TVPaint." I agree.
In the meantime , this custom script panel works to do the job.
Select all your Clips in the Project view.
Then click on the first button under Configuration to set a new prefix for the clips (such as SCENE_ or SC_ or CLIP_ or SHOT_ )
Click the second button under Configuration to set the starting number for the clips as 1 . (I notice that Mads' script doesn't seem to allow for starting
the numbering at anything other than 0 or 1. I don't know if this can be changed by adjusting the script ?)
Then click on the third button under Batch Rename. Now all your selected clips should be renamed.
- Screen Shot 2023-01-11 at 1.29.37 PM.png (33.47 KiB) Viewed 6313 times
