Export FX Stack bin is named incorrectly
Bug in the FX Stack bin export:
When I want to export an FX Stack the name of the FX in the Export/Save panel is the previously exported FX Stack bin , not the name of the current FX Stack.
The name should by default be the name of the current FX Stack that is being exported, so the user does not need to re-type the correct name before exporting the FX bin.
This screenshot shows the FX that is currently loaded. This is the one I want to export. (Repo_Resize_PIG_for_Paparazzi_Scene_01_18_2023)
Now click on Export -
Click to Export FX.png (74.38 KiB) Viewed 1425 times
However, when the Export/Save window opens the name of the FX bin is the name of the previously saved FX, not the
name of the current FX that is being saved. So the user must manually re-type the correct name .(Repo_Resize_PIG_for_Paparazzi_Scene_01_18_2023
Matthieu
Re: Export FX Stack bin is named incorrectly
Post by Matthieu »
Hello David,
I have reproduced this issue indeed and will add it to the bug list for the developers. Thanks for noticing this!
Matthieu wrote: 20 Jan 2023, 11:09 Hello David,
Thank you for adding it to the bug list for the developers to fix.
It's very important that the FX bin being exported is automatically assigned the correct name, otherwise the task of exporting (saving) FX bins becomes extremely tedious.
(I realize this should go under the New Features and Improvement Requests topic, but the other thing that would be very helpful is the ability to choose EXPORT ALL the FX a particular category; for example if I have 100 KeyFramer FX saved in the FX bin and I need to Export those as a back-up or to share with another user, it takes a considerable amount of time to export each of the 100 FX . Export ALL FX in the FX Bin would be extremely useful. I'll add this in the New Features and Improvement Requests topic)
