TVPaint 11.0.0 program crash Topic is solved
I use the “Inlay Texture” effect on my windows7 (TVPaint 11.0.0)to crash, but there's no problem in my MAC pro (TVPaint 11.0.1) !!!
- TVP-bug.jpg (234.16 KiB) Viewed 16065 times
Re: TVPaint 11.0.0 program crash
There it isjosh wrote:I use the “Inlay Texture” effect on my windows7 (TVPaint 11.0.0 to crash, but there's no problem in my MAC pro (TVPaint 11.0.1) !!!
You should update to TVPaint Animation 11.0.1, the crash with the Inlay Texture has been fixed in it.
Thierry wrote:There it isjosh wrote:I use the “Inlay Texture” effect on my windows7 (TVPaint 11.0.0 to crash, but there's no problem in my MAC pro (TVPaint 11.0.1) !!!
But when I hit the download button,It says "There is no new version available."
you should be able to use the menu [Help > Check for update].
If not, use this link : http://www.tvpaint.com/update.php" onclick="window.open(this.href);return false; with your lock and unlock codes.
Thank you for your help, I did it in that step.Fabrice wrote:you should be able to use the menu [Help > Check for update].
I don't know what to do next.
I'll continue with you via email (I removed your photos, just in case)
Im using TV Paint 11.7 and have the same problem. I wanted to ckeck the "inlay Texture" effect and the pragram crashed. I tried several times. Every time the same happened.
should I totally forget this effect or anyone has a solution for it?
Are you accessing the Inlay Texture effect through the menu or by opening the FX Stack by clicking the "magic hat" icon
in the upper toolbar?
Are you using version 11.7 or 11.7.1 ?
I recall a few weeks ago some people reported an issue with the first version of 11.7.1 where opening an FX via the menu caused TVPaint to crash. I believe the issue has been fixed in the latest build of version 11.7.1 (released Dec. 22, 2022 ; if yours is before Dec. 22, 2022, updating should fix the issue)
I have tried both options, but always with the same result.
I bought the program 2 days ago, but I still use the trial version. I think it must be the last version.
D.T. Nethery wrote: ↑21 Jan 2023, 14:57 Are you accessing the Inlay Texture effect through the menu or by opening the FX Stack by clicking the "magic hat" iconin the upper toolbar?
It seems that someone forgot to update the Demo version , because I downloaded the Demo version today (Jan. 22, 2023) to check it and I can see the date is Oct. 27, 2022. So the available demo version is not the most recent version of TVPaint updated on Dec. 22, 2022. Hopefully TVPaint will email your license code soon and you can update it to the latest version 11.7.1 released on Dec. 22, 2022. I think that will fix the crashing problem wth the FX Stack.
When I opened the Demo version and checked under the Help Menu > About TVPaint Animation,
it shows that it is from Oct. 27, 2022 -
Hello, the Demo version download has just been update to v11.7.1
Thank you. I have the registered version now. The effect works.
D.T. Nethery wrote: ↑22 Jan 2023, 14:34It seems that someone forgot to update the Demo version , because I downloaded the Demo version today (Jan. 22, 2023) to check it and I can see the date is Oct. 27, 2022. So the available demo version is not the most recent version of TVPaint updated on Dec. 22, 2022. Hopefully TVPaint will email your license code soon and you can update it to the latest version 11.7.1 released on Dec. 22, 2022. I think that will fix the crashing problem wth the FX Stack.
