Toggle Project Tab?
Sewie
Toggle Project Tab?
Post by Sewie »
I was wondering;
Is there a way to toggle between the Project Window and the Time Line Window? So that I can use the same keyboard shortcut to go to the Project Window and back to the Timeline Window.
Edit: Changed the title to the proper interface terms.
Re: Toggle Project Window?
Sewie wrote:I was wondering;
Keyboard Shortcut = 0 to toggle on the Layer/Timeline panel.
Screen Shot 2014-08-10 at 9.06.51 AM.jpg (33.99 KiB) Viewed 15070 times
Open-Close Timeline-Layer Panel1.jpg (80.19 KiB) Viewed 15072 times
Open-Close Timeline-Layer Panel2.jpg (66.81 KiB) Viewed 15072 times
Sewie
Post by Sewie »
Thank you, David, but I am afraid I wasn't clear; I used the faulty definition for the Project Tab.
What I meant was a toggle between the Project and the Timeline tabs.
So I would like like to know if it's possible to use the same shortcut key to toggle between 1 and 2 in my screenshot above.
Sewie wrote:Thank you, David, but I am afraid I wasn't clear; I used the faulty definition for the Project Tab.
[attachment=0]TVP_Project+Timeline_Tabs.JPG[/attachment]
Yes, sorry, I misunderstood what you were asking about .
Sewie
Re: Toggle Project Tab?
Post by Sewie »
No need to apologize. That was entirely my bad.
NathanOtano
Post by NathanOtano »
You can only use two shortcuts, one for "open timeline panel" in the interface menu and one for "open project panel" in the same menu (if the names are right).
And i don't think there is george comands for those actions, otherwise i'll be able to do a toggle button i think.
oscar
Post by oscar »
Just wondering if there is a solution to this now?
I really appreciate the [TAB] and SHIFT+[TAB] for switching between Clips, but is there also a new a shortcut like Sewie asked for now?
Hello, in TVPaint 11 the TAB key is used by default to toggle between the currentl clip's timeline and the Project view, which displays all the project's clips.
oscar
Post by oscar »
I just noticed Nathan already hinted at the solution. It's a little more thoroughly described here, which is a pretty decent solution I think.
https://www.tvpaint.com/forum/viewtopic.php?t=12425#top
Thank you!
mox
Post by mox »
oscar wrote: 27 Jan 2023, 14:15 Just wondering if there is a solution to this now?
It's possible now to switch from the Project tab to the Clip timeline tab: edit > shortcuts > in the Timeline list, assign Switch to Next Tab
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
oscar
Post by oscar »
OMG that's perfect, exactly what I was hoping for! Thank you so much <3 <3
