No frame count in timeline
- Janet Perlman
The frame count at the top of my timeline has mysteriously disappeared. This is the case for scenes in one of my projects, but when I open another recent project, the numbers are there. If I open preferences, the numbers immediately reappear. Then when I click on the other scene, and go back, the numbers are gone again. Any idea what is causing this?
- Timeline.png (84.83 KiB) Viewed 1870 times
- Janet Perlman
Re: No frame count in timeline
When I put an end point to the scene the problem disappeared. It still means I had to make an instance to the length I wanted for the scene, just so I could find the spot for the end point. So that's the minor workaround.
That was a bug in 11.7 which was fixed in 11.7.1 . Make sure your software is updated to version 11.7.1 (released on Dec. 22,2022).Janet Perlman wrote: ↑12 Feb 2023, 02:17 The frame count at the top of my timeline has mysteriously disappeared. This is the case for scenes in one of my projects, but when I open another recent project, the numbers are there. If I open preferences, the numbers immediately reappear. Then when I click on the other scene, and go back, the numbers are gone again. Any idea what is causing this?
You can check the version number under the Help Menu > About TVPaint Animation
- Janet Perlman
Thank you. I will do that.
