Hi all,
somehow tvp (11.7.1-64bit WIBU version) lost the camera preview function (after clicking the play with camera, it does follow the camera in preview.)
And also It doesn't force the proxy render in (I checked in the preview settings), so the animation preview is laggy and hard to look at.
Ant idea what is wrong? Much appreciated guys!!
**** I can still work on tvp and export the WIP to mp4 to check..... but it is just very troublesome.
My mac info: venture 13.2.1 detail see attachment
TVP cannot show the Camera preview and Force proxy render Topic is solved
- Screenshot 2023-04-14 at 08.24.36.png (50.66 KiB) Viewed 4451 times
- Screenshot 2023-04-14 at 08.22.58.png (12.63 KiB) Viewed 4451 times
Re: TVP cannot show the Camera preview and Force proxy render
Hello, does unticking the Preview square in the FX stack make things better?
Hello Dean,
it works! thanks! Have a good day!
This is a bug we are aware of and fixing for the next update (:
You meant unchecking the Full Quality Preview box in the Preview Settings, not FX Stack, right ?
So unchecking the box for Full Quality Preview should fix the problem with the Camera View not displaying correctly in TVPaint version 11.7.1 ?
I have unchecked the Full Quality Preview box on mine , but it does not fix the problem with the Camera View not displaying correctly.
I really meant the FX stack, we have recently found that this thing is linked to the camera view playback issue (it was mentioned on another thread, I think).
Ok.
And now I've had time to test it. Yes, uncheck the box next to Preview in the FX Stack to fix Camera View playback issue ! Very interesting.
I would never have guessed that the FX Stack Preview had anything to do with the Camera tool. How did you ever discover the connection ?
Apparently you only have to uncheck the Preview box in FX Stack one time , because I noticed when the FX Stack is closed and reopened the Preview is checked again,
but unchecking it one time fixed the problem with the Camera View playback.
Just had this bug and can confirm that unchecking the preview from the fx stack worked. Appreciate the feedback as on any normal day this would have stumped me to try figure out, thanks!
I've been suffering from this problem all day, but thanks to you, I solved it.
When the preview was activated in the fx stack, not only the camera problem but also the 'play from current frame' function operated abnormally.
