Scribbly notes panel in timeline super glitchy, colourful pixelly static.
melaphant3
Post by melaphant3 »
Hello, just wondering if there's a fix for this issue I'm having so I can get my notes back.
I've recently updated TVP to the latest version and migrated all my stuff over to a new mac (M1 Max, Ram 64GB, Ventura 13.4) I'm having trouble with only the moved files and not any new ones I create now.
I took a screenshot video to show exactly what's going on but I'm not sure how to post it easily on this forum so here's a drive link instead
https://drive.google.com/file/d/14ILTAv ... sp=sharing
Any way I can get my notes back?
Another thing I was going to ask about was my audio was uneditable and unmuteable (it would visibly look edited, but nothing sound changed on playback or by timeline scrubbing - even if I deleted all the sound) since the file migration, but as soon as I enabled sound via quicktime's screen recording it was resolved! I couldn't believe it.
I thought I'd add that here in case it helps anyone else out. Quicktime's always been the route of my audio problems with TVP.
Sometimes I tumble : D
http://melaphantastic.tumblr.com/
Re: Scribbly notes panel in timeline super glitchy, colourful pixelly static.
Hello could you check if the issue persists with a fresh configuration file, please?
First, you might want to backup your custom brushes and shortcuts:
https://www.tvpaint.com/doc/tvp11/index ... m-settings
The config file is located in Library > tvp animation 11/pro > default > config.ini (I suggest you backup your current config.ini somewhere or rename it to "config_" so TVPaint creates a new one at launch).
But the system Library folder is hidden by default on MacOS, you can follow this guide to reveal it:
https://crunchify.com/have-you-noticed- ... os-x-lion/
melaphant3
Thanks for waiting Dean :)
Just had a chance to try that and it still does it, unfortunately.
Oh that's too bad. Are you using a Retina screen?
melaphant3
Ah, yeah I am. I can't test it on a regular one unfortunately, but I bet that's it!
Oh well, some of my notes do still show up if I get in really close. That'll have to do it for me, haha. At least it's pretty.
dmceachern
Post by dmceachern »
I'm having the same issue on my Mac Studio M1 Ultra, 128 gb, Ventura 13.5.1 with Wacom Cintiq Pro 24, though I have TV Paint launching in low res mode. Is there anyway to fix this or is it a bug of some sort? Also is there any word on a native ARM version of TVPAINT for Macs? Things run fine for the most part but I do occasionally find things a little laggy which I assume is the emulation.
A native ARM build of TVPaint is currently under development :)
dmceachern
Awesome to hear! Thanks!
