Copy-pasting frames from another file not working
Soom
Post by Soom »
TVP 11.7.1 Pro
I am copying a selection of frames from one file to another.
Pasting these frames results in one empty frame at the beginning and one missing frame at the end.
Please see screenshots:
copying 6 selected frames from one file:
Screenshot 2023-09-21 111952.png (9.22 KiB) Viewed 6340 times
result of pasting in another file:
Screenshot 2023-09-21 112124.png (15.18 KiB) Viewed 6340 times
copying and pasting the same frames inside the same file works fine.
https://vimeo.com/danas
Re: Copy-pasting frames from another file not working
Check if in the original file the layer is locked.
Soom
Post by Soom »
slowtiger wrote: 21 Sep 2023, 12:27 Check if in the original file the layer is locked.
I checked. It's not locked...
Soom wrote: 21 Sep 2023, 09:29 TVP 11.7.1 Pro
I am able to do this on my end with no problem. (TVPaint 11.7.1 , MacOS Monterey).
OK, since I made that mistake just recently: those are not empty frames in the original?
Soom
Post by Soom »
slowtiger wrote: 21 Sep 2023, 16:58 OK, since I made that mistake just recently: those are not empty frames in the original?
naaah, I am not that tired :D
you can clearly see in the screenshot it's not empy - it just pastes everything with a shift of one frame
i have the same issue.
when i copy a selection from one project to another the first frame is left empty while the duration of that first instance is taken from the selection length of the first instance of the copied frame
and also still encounter the bug where tvpaint does not display framenumbers nor timecode...
frames pasting bug.jpg (71.19 KiB) Viewed 5465 times
