License rehosting error! Topic is solved
Hello!
I was using tvpaint yesterday without any issues, I closed the program and when I came back to it and reopened it again, it was saying that I didn't have the license to work on tvpaint. I checked into my codemeter profile and there were two licenses (one temp), both activated. And when I went to rehost the license, it showed the following error.
I uninstalled everything and reinstalled a fresh download and still the error persists.
Is there a solution to this?
- Screenshot 2023-09-22 at 9.42.22 PM.png (52.64 KiB) Viewed 7313 times
MacBook Pro 2019 / macOS Sonoma 14.0 / Core i7 / 16 GB / Intel UHD Graphics 630 1536 MB / Cintiq Pro 16 / TVP PRO 12 64-bit
Re: License rehosting error!
Hello GJeaks, so the issue appeared overnight?
Did you recently install a major OS update, clone or format your hard drive?
Could you send me a screenshot of your Codemeter's main window via PM, please?
Hi Dean,
I installed an audio interface and have used 'first-aid' from the disk utility, but that's about it. Nothing other than that. I'll send you a PM of the codemeter's main window.
Hi, I need some more screenshots, I just responded to your PM
HI,
Has anyone else faced any issue like this? I'm in the middle of a project and I need to get it fixed soon T-T I'm trying to salvage it by using other software but it'll be great if there is a solution to this.
Dean, I have shared the relevant screenshots with you. I feel that the problem is a license rehosting issue, and if the license can be reset I can probably get tvpaint to work. Can it be done from the backend? (I'm just speculating on the solution)
Everytime I open tvpaint I get this window
...and I have tried reinstalling it multiple times too.
Hello, just responded to your PM, according to what I see, a simple remote license rehost or Codemeter update will be necessary.
Thank you so much! the issue is resolved.
Does anyone know why my CodeMeter control centre say "CodeMeter service has been stopped'
Hello, which operating system and Codemeter version are you currently using?
My issue has come back after a force restart T-T
