Audio playback crackles distorted Topic is solved
Re: Audio playback crackles distorted
fmhansen wrote: 20 Aug 2023, 02:11 FIXED.
I ended up deleting my config file, like kelanhordos suggested BUT first saved all my custom settings, as Dean said, and the crackle is 100% gone. Thank you all!
Good news ! I'm glad that creating a fresh config fixed it.
fmhansen
Post by fmhansen »
This "audio crackle" issue came up again when I loaded new audio and even affected the audio that HAD BEEN fine. I tossed out my config.ini, which fixed the issue, but frustrating just the same.
Hello, even after setting the sampling rate to 48000khz?
elars27
Post by elars27 »
None of these steps worked for me, and every reference video I import on my Mac is distorting. No issues on PC, but can't use PC as I'm traveling.Image
Screenshot 2023-12-21 at 2.43.08 PM.png (75.28 KiB) Viewed 6063 times
Hello, does using a fresh config file fix the issue?
