Can't resize output when exporting layers as json+images Topic is solved
KonradHjemli
Post by KonradHjemli »
Hello! I have a weird issue with my export menu, and can't find anyone else with the same problem. When changing to the "Clip: Layers structure" tab, the option of converting the output to a different resolution disappears.
Here's how it looks for me:
convert to section gone.png (53.95 KiB) Viewed 4791 times
In all other screenshots I've seen of this dialog, the "convert to" section is visible here between the compression slider and background tickbox.
And in the other tabs, the option is visible like normal:
here it is visible.png (57.57 KiB) Viewed 4791 times
However changing it here and then exporting from the Layers structure tab doesn't make the conversion apply to the output.
Lenovo Yoga, Windows 10
AMD Ryzen 7 4700U with Radeon Graphics 2.00 GHz
16GB RAM
Wacom Cintiq 22
TVPaint Animation 11 Pro 11.7.1-64 bits
Cardin
Re: Can't resize output when exporting layers as json+images
Post by Cardin »
Hi, Konrad!
The option to change dimensions in Clip:Layer Structure was introduced in 11.5.3.
Your current signature indicates you're on 11.5 but doesn't specify which iteration.
Perhaps you're on an older version, so updating might resolve the issue?
changelog snip
changelog snip
TVPaint 12.0.0 Pro
KonradHjemli
Ah, you're right, turns out I was on 11.5.1...
Was indeed time for an update! :lol:
16GB RAM
Wacom Cintiq 22
