Export clips to TVP projects
Joost
Post by Joost »
Hi!
Is it possible to export every single clips in my "project" tab so they become separate TVPaint projects (and it would be even better if every project would be saved in de separate folder).
Screenshot 2024-03-04 at 08.14.37.png (73.22 KiB) Viewed 6991 times
For example: See this image. They are all called "shot 01", "shot 02" and so on. I would like to have these shot as a separate TVP file in a folder with the same name and it would be really helpful if this could be automated.
Joost
TVP Pro 11.7.1
Hironori Takagi
Re: Export clips to TVP projects
Post by Hironori Takagi »
I created it using Clips To Projects in Handy Custom Panel.
What do you think?
AllClipToProject_240304.grg
(2.65 KiB) Downloaded 416 times
Joost
Post by Joost »
Wow! this is exactly what I meant!
Thanks you so much!
Best,
Joost
TVP Pro 11.7.1
Thank You Hironori San!
i asked for the exact same thing about a year ago.
https://forum.tvpaint.com/viewtopic.php ... ts#p132808
I believe this function "Export clip as project" should be integrated in the project menu. or be available in the main clip menu.
But project view maybe makes more sense as you can select the clips you need to save.
i do ran into an issue with the script.
if i run it i get the warning "プロジェクトを保存してから実行して下さい Please save project."
but when i save the project and try again i still get the warning?
something to do with a period in the project name? i don't understand
Often repeated warning: avoid anything outside 7bit ASCII in file and path names. So it's A-Za-z0-9_ only.
Joost
Post by Joost »
Peter Wassink wrote: 04 Mar 2024, 10:35
I agree that it should be integrated!
A couple of things I thought about (If it would be implemented)
-It would be handy if it asked where to save the files
-Have the ability to save each created file in a sub-folder (with the same name)
-Maybe it would be better if it not automatically opened every file
-And there should be a good method of giving each clip a logical number without renaming every clip by hand
TVP Pro 11.7.1
Joost wrote: 04 Mar 2024, 11:52 A couple of things I thought about (If it would be implemented)
I agree with all of these.
this topic has been addressed multiple times
https://forum.tvpaint.com/viewtopic.php ... 49#p131749
i can only conclude this needs some attention from the development team, its clear this important functionality is lacking.
meanwhile here is the direct link to the custom panel patch: https://www.tvpaint.com/forum/viewtopic ... 03&p=47609
Hironori Takagi
Peter Wassink wrote: 04 Mar 2024, 10:35 i do ran into an issue with the script.
This program checks exist periods in the file path to avoid running it on unsaved projects.
It should be cleared if ".tvpp" exists, but if there is a space in the middle of the project name, it may not work due to George's rules.
Turned out it was a simple copy/paste mistake.
i omitted the first line of the grg script :roll:
It works now. Thanks!
AllClipToProject_Hironori Takagi.tvpx
(7.5 KiB) Downloaded 409 times
Peter Wassink wrote: 05 Mar 2024, 12:57 Turned out it was a simple copy/paste mistake.
Thank you Hironari Takagi for this very useful script.
Thanks to Peter for putting it into a custom panel .tvpx file.
Lukas
Post by Lukas »
I reworked it a little bit for our pipeline. My version is in my panel: https://github.com/lukaskrepel/TVP-Lukas-Sketch-Panel make sure you update to the latest version.
Read the Suggested folder structure for projects part of the readme if you're interested in using it too. There's a "Clips to TVPaint Projects" button to go from STB to Folder structure with a file per clip. And a "Render to 'Renders' Folder" button that renders a shot as image sequence into the correct folder each time. It saves a *lot* of time, as the default Export window is a often hassle to work with imo.
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
