Suggestion to be able to do this for any filled shaped on the fly.
Keyframer FX can be used for this but it needs a bit of workaround and several steps to achieve the same result to fill shapes of any kind.
Pic1: When you fill a rectangle using brush warping (tile option on both X+Y)
Pic2: same thing using the brush with an angle of 5°after being edited.
Suggestion to match the new edited brush
Brush Warping
Brush Warping
- brushwarp2.png (65.2 KiB) Viewed 4022 times
Re: Brush Warping
weird, if i set an angle on the brush and then try to do a brush warp with the filling shape, there is no rotation?
how do you set the angle?
Re: Brush Warping
Because I'm using Edit Brush for this and I forgot to mention it...
You're right, modifying the angle or other options available in the Tool: Custom Brush panel does affect the strokes but not the "filled shapes" at all, I never realized that!
It should have a reason that prevents this but I don't see what right now
