Color pick current layer only
TVPUSER
Post by TVPUSER »
I was recently showed a photoshop plugin that allows us to set the sampling mode for the color picker.
It simply makes so much sense especially for those of us who like to use layer modes for lighting effects..
Setting the color picking mode to current layer samples the normal color info regardless of layer mode!
Tvpaint already has a similar feature when sampling for color filling
Perhaps it is a little bit of a niche ask but I think this is an easy productivity boost for many.
Video in action:
TVPaint 11.7.3, 12.0.1 Pro 64, Windows 10 H
i7-8700k, 48GB, RTX 2080 8G Desktop, Cintiq Pro 24 (3840x2160)
Ryzen 9 5900HS,16GB, RTX 3060 6G Laptop, Wacom ONE 13 Touch (1920x1080)
Re: Color picker sample layer options
I remember Mark Chong (Lemec) once built an elaborate colorpicker for TVPaint that looked just like that.
Perceptual Palette.
If i remember correct it no longer worked in the 64bits version...
anyway i don't have it anymore. Not sure if Marc is still around?
TVPUSER
Post by TVPUSER »
Peter Wassink wrote: 14 Mar 2024, 21:30 I remember Mark Chong (Lemec) once built an elaborate colorpicker for TVPaint that looked just like that.
Perceptual Palette.
There it is!
You're right it isn't compatible with 64-bit :cry:
Perhaps there is a way to achieve this in george script?
I do like the notion of it being a toggle, though I don't think you can do that with the scripting.
Jeremy Richard
Re: Color pick current layer only
Post by Jeremy Richard »
TVPUSER wrote: 15 Mar 2024, 01:50 Perhaps there is a way to achieve this in george script?
I don't know if it's exactly what you are looking for, but with Svengali's script you can select the actual colour on the active layer even if you are using blending modes.
tv_LockMouse 4
tv_WaitButton
parse result ButtonState X Y
tv_GetPixel X Y
parse result R G B A
tv_UnLockMouse
IF A > 0
    tv_SetAPen R G B A
ELSE
     tv_warn "no pixel color found"
END
TVPUSER
Post by TVPUSER »
Jeremy Richard wrote: 22 May 2024, 16:49
tv_LockMouse 4
tv_WaitButton
tv_GetPixel X Y
tv_UnLockMouse
IF A > 0
    tv_SetAPen R G B A
ELSE
END
Brilliant! This is the functionality i'm looking for! hope some official option comes along but setting a hotkey to the script will suffice!
