I would also like to ask for the ability to draw out of the canvas.
If I try to animate a character walking outside, I need to see at least one keyframe outside to animate to.
Is this difficult ot create?
drawing out of the canvas
i don't know how difficult this would be.
but in the digital realm it is even thinkable to have no border to your work canvas.
but in the end you will always need certain dimensions for your output.
and you have to decide on your 'camera framing' and 'output dimensions'...in other words...what part of your workcanvas goes finally to the 'big screen' and in which resolution.
this is no different in TVP
the only thing is that people generally tend to work in a project of the same dimension as their final output.
But this is not at all necessary you can easily crop your project dimensions larger to accommodate extra playing room for camera moves or cases like you describe where you need a key position outside the frame.
so the best current workaround is to crop your frame wider.
- off-project.jpg (36.01 KiB) Viewed 18268 times
- toonsisters
ah... yes i forgot to mention that..toonsisters wrote: I only have to create a transparent layer with my final output size, so I can keep the overview.
i always do that too! (i keep it locked and at 50% transparent)
Mensch sind wir klug...
Re: drawing out of the canvas
this would be a great feature to add, good idea!
