Align Layer Left/Right function is not refreshing the screen after the current Update.
I've just update tvp from the 11.5.1...? I think, to 11.7.3.
So I don't know from when.
but I think 11.7.0 or 11.7.1 had a not-rendering preview issue, so I do not use those version but tested once,
but there was not a bug like that. So it seems that this started to occuring after that versions.
Because I control the timeline only with my keyboard, It's pretty annoying.
so, I hope it to be fixed.
The symptom is like the thing when I edit the Xsheet layer's intance name, It's not render the screen instantly,
I have to Do more action on the timeline or on the screen, that has a some kind of having the screen refreshing-thing.
I think this fuction's not having the screen-refreshing action.
I guess on the normal layer, renaming the instance action do not need the screen-refreshing,
so if the Xsheet copied from the normal layer structure during making the tvp, It can be occure.
so, at first time I aligned the layers on 11.7.3, I thought It's the same ploblem like X-sheet's instance name editing,
It seems the screen-refreshing action after the fuction was gone somehow.
If it's possible, I hope screen-refreshing to be fixed (or added) after we use these.
-Aligning layer fuction on timeline.
-after the X-sheet's instance name editing
Thank you always.
Align Layer Left/Right is not refreshing the screen 11.7.1-11.7.3 [TVPA-3599] Topic is solved
Re: Align Layer Left/Right function is not refreshing the screen after the current Update
I found there's some rule on the bug.
It occures only when I align the layer to the 'specific point' which is over the layer end, or before starts of the layer.
If the aligning point is in the between of starts and end of layer, It functions normaly.
240529
Here' s another issue,
When the screen is not refreshed, after the aligning layers, Transform function is blowing away the image.
Oh, I just found tvp 12 came.
That's wht there's any response......
Is there any way to get the installer of 11.7.2 version of windows 64bit?
or I hope if there's anyone can check this on 11.7.2,
please share the result of it.... please...
Re: Align Layer Left/Right is not refreshing the screen 11.7.3
I just got the installer of 11.7.2 from the contact to tvp website...
and there is same ploblem is occuring.......
Re: Align Layer Left/Right is not refreshing the screen 11.7.1-11.7.3
It's the gif of the symptom
![Image](https://i.imgur.com/9T1RLD2.gif)
Re: Align Layer Left/Right is not refreshing the screen 11.7.1-11.7.3 [TVPA-3599]
Thank you for your feedback.
The dev team was able to fix this issue for the next update.
