TVPaint Animation 11.7.3 is available!
Re: TVPaint Animation 11.7.3 is available!
We have found what was causing the issue.
We will try to release a hotfix next week, addressing this and a few other problems as well.
Tsuchida
TVPaint Animation 11.71 11.72
Post by Tsuchida »
Installers of past versions
The problem with the Japanese display of 11.73 is described in the forum, but has not yet been solved.
We would like to use the older version. Could you please share the link to the installer of the past versions?
11.71 Standard and Pro Safenet (dongle) versions
11.72 Standard and Pro Safenet (dongle) versions
Hotfix is coming either today or Monday, I'll keep you in touch.
We've released a hotfix that addresses the following issues:
  • Fixed a crash that was happening when changing language.
  • Fixed a crash that was happening in the About Panel.
  • Fixed version not updated on macOS menu bar.
  • Vertical Timeline option has been brought back.
You can download it from your User Account.
Hironori Takagi
Post by Hironori Takagi »
I confirmed the normal operation of the Japanese menu on TVPaint11.7.3 Apr 18 2024. Thank you for your update.
rohandeshchougule
Post by rohandeshchougule »
Hello! I am still having some random crashes on my M1 Pro with Sonoma 14.4.1. They are not too often but they do happen none the less. I tried resetting user config and restating code meter from scratch. Not sure what the issue is really. I'm back to 11.7.1 for now.
maara_p
Post by maara_p »
Hello!
Just wanted to say I really like the changes to the export settings ("Empty images", "Duplicated images", "Exposure cells"), so far tested it once and it works great as expected. For me this was an important change. So – Thank you!
rohandeshchougule
Hello! Not sure if this is MAC issue or TVPaint issue, but it doesn't happen on other applications. What I have noticed is, specially 11.7.3 crashes when it is in full screen mode (when it goes to a different workspace) on my M1 Pro running latest Sonoma. It runs pretty much without crashes if it's in 'windowed' mode. Has anyone else faced similar issue?
Hello Rohan, this could be a new lead. Would it be possible for you to post a short video of this?
rohandeshchougule
Hello! Not sure how to record your screen on Mac and fingers crossed that it happens while it's in full screen. I will get back to you on that.
rohandeshchougule
Dean wrote: 21 May 2024, 09:44 Hello Rohan, this could be a new lead. Would it be possible for you to post a short video of this?
Hello Dean!
I have not been able to replicate the crash as it seem to be random, although not frequent, which is a good news I think :) But because it's so random, I won't be able to record the screen all the time. I will though save the report if it pops up during next crash and put it here. Thanks!
rohandeshchougule
Hello Dean!
There you go, just had a crash while working in full screen. Attaching the report.
TVPaint CRash Report.pdf
(100.87 KiB) Downloaded 564 times
deruji
Post by deruji »
Any update for the timeline on the Linux version for 11.7.3?
The traditional 2D animator working with local and international artists.
You can help support my work to make traditional animation, here.
rohandeshchougule
Is there any update on the crashes? I'm still on 11.7.1 as 11.7.2 and 11.7.3 crash on my MacBook M1 PRO running Sonoma. I had posted crash report last time.
mikdog
Post by mikdog »
Does anyone have any info on whether TVP 11.7.3 runs ok on Mac Sonoma? I haven't updated my OS in years (I'm still on Big Sur) because I really don't want apps that bug out and crash - often seems like a major downgrade instead of an upgrade.
Any help greatly appreciated, thanks.
