I can't get the gradient function to work Topic is solved
BruceM
Post by BruceM »
I'm trying to do a simple background gradient by following a TVPaint tutorial but it's not working. After setting my 2 colors in the A & B color boxes and checking the "Gradient" box, when I click on the project window, it's not turning into the checkered screen as in the tutorial, and drawing the stylus across the screen does nothing but leave a colored line.
Does anyone know what I'm doing wrong?
-Bruce
Re: I can't get the gradient function to work
Gradient works best and most obviously in cases where you fill a surface.
for instance with paintbucket, filled rectangle or filled stroke.
using this panel:
gradient options 0.jpg (18.48 KiB) Viewed 2075 times
You can, in some cases, also use gradient in line drawing tools but not with all brush types.
for instance
an airbrush with reduced opacity shows it well even without pressure sensitiv input:
gradient options1.jpg (24.13 KiB) Viewed 2086 times
the penbrush gives you this: but you do need pressure sensitivity
gradient options2.jpg (28.86 KiB) Viewed 2078 times
btw
did i find a bug?
the drawing mode "B Color to A Color" does nothing?
In the documentation there is no mention of this mode and on what this drawing mode is supposed to do
but i would imagine it working like the fade connection setting
that it would change color from B to A during the applying of a stroke
broken?:
gradient options3.jpg (16.72 KiB) Viewed 2076 times
#edit#
ok i remember, this mode changes all pixels that have color value B into pixels with colorvalue A
So you could see it as a re-color mode.
that is why it does nothing on an empty frame. it needs pixels of color B to work
BruceM
Post by BruceM »
You saved me twice in one day!
Thanks again, Peter!
