Color coded layer icons V5 for TVP 11 - 12.0
TVPUSER
Post by TVPUSER »
I was really used to the colors of the layer icons in previous versions of TVPaint so I decided to colorize the current icons with the colors of the older version of TVP
For those who are stuck in the past!
V1 03/12/2021
V2 11/12/2021
UPDATED V3 10/10/2022
New TVP 11.7 Icon scaling options
Removed the other outline options for simplicity (they all had a worse visual read anyways)
UPDATED V4 12/2/2022
Added Stencil Icons
Added alpha lock Icons
UPDATED V4.1 03/11/2023
Changed Preserve transparency icon to a CYAN color, the rainbow colors made it hard to identify the icon.
UPDATED V5 06/13/2024
TVP12 Icons added
-Some icons are reused in the GUI for layer controls so most of the icons are simple recolors except for layer visibility.
Color_Coded_Layer_Icons_v5.zip
(665.03 KiB) Downloaded 378 times
TVPaint 11.7.3, 12.0.1 Pro 64, Windows 10 H
i7-8700k, 48GB, RTX 2080 8G Desktop, Cintiq Pro 24 (3840x2160)
Ryzen 9 5900HS,16GB, RTX 3060 6G Laptop, Wacom ONE 13 Touch (1920x1080)
tribute27
Re: Color coded layer icons
Post by tribute27 »
I like it! Thanks! I didnt even know you can customize the little icons
Great work!
TVPUSER
Re: Color coded layer icons v2
Post by TVPUSER »
Updated to v2 :)
TVPUSER
Re: Color coded layer icons V3 11.0 - 11.7
Post by TVPUSER »
Updated to v3 for TVP 11.7 update!
Thank you !
CartoonMonkey
Post by CartoonMonkey »
This is an EXCELLENT idea!
TVPUSER
Post by TVPUSER »
Quick upload update v3.1
made 11.5+ dark light folders for consistency
TVPUSER
Re: Color coded layer icons V4 11.0 - 11.7
Post by TVPUSER »
V4 Update, Added more icons
CartoonMonkey
Absolutely wonderful! TVPaint should adopt these by default. (If you'd let them!)
CartoonMonkey wrote: 09 Dec 2022, 21:15 Absolutely wonderful! TVPaint should adopt these by default. (If you'd let them!)
Agreed !
TVPUSER
Post by TVPUSER »
I'd love to see them bring back some color coding in a future update for sure!, The icons I made were really quickly made so they'd probably have a better solution than mines.
I think I went a little too far with the preserve transparency icon, it just does not read very well from afar so I'm thinking of changing it really soon here.
New version is now uploaded!
TVPUSER
Re: Color coded layer icons V5 12.0
Post by TVPUSER »
TVP12 Icons added
