TimeSheetPanel(SelfCustomize)_240816
Hironori Takagi
Post by Hironori Takagi »
I checked whether the custom panels I had created so far would work with TVPaint12,
and found that in many cases they did not work due to changes to the specifications of the camera layer, folder, and image mark.
I'll share one test I did, where I modified "TimeSheet" so that it would not stop in V12.
The main changes were:
- Determine whether it is version 12 or later or earlier
- For version 12 or later, skip layer types "Camera" and "Folder" when searching
- For version 12 or later, the information acquired for image marks has changed from "ID" to "ID R G B", so only the first part is acquired
There may be other specification changes, so please let us know if you notice any.
sheet_inbetween8-2_240816.grg
(26.98 KiB) Downloaded 1051 times
sheet_inbetween_standalone8-2_240816.grg
(50.86 KiB) Downloaded 1041 times
sheet_key8-2_240816.grg
(52.08 KiB) Downloaded 1012 times
TimeSheet_240816.tvpx
(287.5 KiB) Downloaded 1072 times
NathanOtano
Re: TimeSheetPanel(SelfCustomize)_240816
Post by NathanOtano »
Thank you!
