tv_LayerMove issue
Hironori Takagi
tv_LayerMove issue
Post by Hironori Takagi »
I'm thinking about making a panel I created previously called "LayersChange" compatible with Ver.12.
It seems that tv_LayerMove can "move outside a folder," but not "put inside a folder."
Is there any way to do this?
LayersChangeDown_181113.grg
(4.54 KiB) Downloaded 131 times
LayersChangeUp_181113.grg
(4.49 KiB) Downloaded 135 times
Hironori Takagi
Re: tv_LayerMove issue
As for tv_LayerDuplicate, if you run it on a layer inside a folder, it seems to be created outside the folder rather than just below it.
Please check this as well.
Hironori Takagi wrote: 26 Sep 2024, 09:16I'm thinking about making a panel I created previously called "LayersChange" compatible with Ver.12.
If you move a layer between two layers that are in a folder, it will be put in that folder.
But I agree that this should be easier.
After discussing with Kévin, we'll add a folder ID as an optional parameter to tv_LayerMove. If that ID is present, the command will put the layer in that folder.
Hironori Takagi wrote: 27 Sep 2024, 05:53 As for tv_LayerDuplicate, if you run it on a layer inside a folder, it seems to be created outside the folder rather than just below it.
We've confirmed that today as well.
Hironori Takagi
Thank you for considering this issue.
I look forward to your continued support.
