suggestion for Tool: Select:
It would be nice to have a "display" option to check, this way we could do the actions for the display, instead of the current layer only.
Tool Selection
Re: Tool Selection
i'm thinking why?
the selection is in fact always over the entire project and not layer based.
so if you apply an effect or a tool on multiple layers it will then make use of the selection in 'display' mode anyway, just as you request here, no?
i wanted to test if my assumption was correct.
by applying a blur on all layers while a selection is active...
but it did not work as expected! one of the lines in this example simply vanished !?
weird bug
in the preview only the active layer gets a preview of the effect
if you are on the purple layer and apply the purple line disappears
and if you are on the green layer when you apply the green layer disappears...
however if you `then click anywhere the layer pops back up with both layers showing and with the applied FX on both layers in the selection area only.
note FXstack is set to 'apply on all layers' .
the active layer disappears after applying... .
but clicking anywhere brings it back with the added FX
weird bug
Re: Tool Selection
I wonder if Max is maybe thinking along the lines of this being useful as an option for affecting layers like the drop down menu in the transform tools? Right now there is Current Layer/Current Group/All Layers/Selected layers, but perhaps a DISPLAY would be useful as a quick way to select the layers that are enabled rather than having to select them all/add them to color groups etc. I could see this being really useful in theory, although all the apply on multiple layer tools are a bit cumbersome to use at times due to lack of being able to see a preview of multiple layers. Hoping we get the ability to see all the layers affected in the preview in the life of v12!
Peter are you using v12.0.2? I've had some "refresh" issues where the display doesn't seem to update over the couple days until I scroll over it when I've done a few things like transformations/pasting etc. I can't remember if this was happening before the new patch, maybe related but could be a coincidence.
One interesting thing that v12 added is under the ERASE tool there is now a drop down "Apply ON" box as well. It is a bit laggy, but gives you the ability to erase on multiple layers at once.
Tvpaint 12.0.1 Pro
Tvpaint 12.0.1 Pro
Re: Tool Selection
Yes, each FX can be applied on all layers at once within a selection indeed.
But outside the FX Stack? In the case you make a selection and want to copy/cut to brush the whole display, you can't. You have to crop to a new project then you will be able to make the brush.
About the "Erase tool" I don't remember it was a thing until now!
So what does prevent this option to be available everywhere?
Re: Tool Selection
Hi Max, maybe I am misunderstanding, but regarding cut/copythe brush, isn't that what the "Display" option already does if you have it toggled?
Also just for clarity in regards to what I said above, I was thinking outside the FX stack when you use the transform/perspective tool, in this menu.
Tvpaint 12.0.1 Pro
Tvpaint 12.0.1 Pro
Re: Tool Selection
Yes, that is my point, to have the same option for the selectionkelanhordos wrote: ↑09 Oct 2024, 13:48 Hi Max, maybe I am misunderstanding, but regarding cut/copythe brush, isn't that what the "Display" option already does if you have it toggled?
When the stencil is on, you know/see what you are grabbing, it is accurate while cutting a brush is on the fly.
Re: Tool Selection
Oh, I think I understand now. There actually is a way to do what I think you are looking for, you just have to use display on/off under the cut brush tool before using select. You probably already know this and are just looking for the option for these settings in the select menu, but just in case.
All of the options under cutbrush tools; copy/cut, display, keep etc. will affect the Shortcut > Shape Select > Copy to CustomBrush, which you can use with a selection from the select tool.
For example
Go to cut brush, and make sure DISPLAY IS ON
Use the freehand select tool > make a selection
Use the shortcut(you will have to assign a key to it) > Shape Select > Copy to CustomBrush
This will act just like the cut/copy brush but with the select tool, and viola you have your brush cut with the DISPLAY and your selection, rather than just the single layer, and you can use the select tool to precisely grab what you want.
Now that I realize what you are asking, I remember also finding it annoying to have to go into the cutbrush menu to toggle those settings to affect my selection, as sometimes you want the display, sometimes just the layer. I would actually think if it wouldnt break anything the whole menu of cut options could be under select for using that shortcut so you don't have to go back to the cut tool. It's actually the predominant way I cut/copy things, because as you mentioned if you mess up when using the cut tool, its "on the fly" and you have to reselect, which obviously is also useful in it's less buttons, but sometimes I need several selections on the canvas to cut/copy as well.
I made a script for myself to toggle the DISPLAY option so I don't need to go into that menu, and it also stays on your current tool. I'm not sure if it's the best way to do it or if there is any bugs(it works well enough for me until now), or another script on the forum somewhere that is better, but you can try it if you like. You can add this code to a embedded script in an action and it should work(the //print stuff is for debugging but also a reminder of whats happening).
Maybe another alternative would be these options in the cut menu should be able to have shortcuts that can be set by default. And while mentioning it, the other toggleable options like drying/warp/projection should all have shortcuts by default in my opinion.
For example
tv_getactiveshape
curshape = result
IF CMP(curshape, cutrect) == 0
//print "not cutrect"
curtool = null
tv_getactivetool
parse result curtool _
tv_cmd tv_setactiveshape cutrect display
parse result _ displaystate
tv_getactiveshape
tool = result
//print tool displaystate
IF displaystate == 0
//print display ON
tv_cmd tv_setactiveshape tool display 1
ELSE
IF displaystate == 1
//print display OFF
tv_cmd tv_setactiveshape tool display 0
END
END
//print Other tool active
tv_getactivetool curtool
ELSE
//print Cutrect
tv_getactiveshape
tool = result
//print display ON
ELSE
//print display OFF
END
exit
test = CMP(curtool, cutrect)
If test == 0
END
END
END
Tvpaint 12.0.1 Pro
Tvpaint 12.0.1 Pro
Re: Tool Selection
Thanks to your detailed explanation, I found out why where was maybe a bit of a misunderstanding.
If I follow the steps you wrote not using a shortcut (for copy to custombrush for instance), it won't grab the display, layer only.
Using a shortcut it does work! It makes no sense
That means it is possible to do it, it is working in the engine but the option is not "linked" to the menu/buttons?
I never used a shortcut for this very option, so I don't know if it's an old feature or a bug
Re: Tool Selection
Haha, Oh that's very interesting and now I see more where you are coming from! I don't remember if I actually ever used that menu for copy/cut, at least not in a long time so I didn't realize it didn't work the same way. Probably a bug?
Tvpaint 12.0.1 Pro
Tvpaint 12.0.1 Pro
