[TVPaint12] DLL Plugins don't works Topic is solved
Ben_QuadGroup
Post by Ben_QuadGroup »
Hi,
It seems currently no dll plugins can work on TV Paint 12.
Our dev team (maintaining QuadPype) wanted check if our TV Paint plugin (dll) used in the pipeline solution is supported and work on TV Paint 12.
The issue is that TV Paint 12 introduced changes in the GUI that broke compatibility with ALL existing (dll) TV Paint plugins including all the example plugins shipped in the SDK archive.
After talking to the TV Paint Product Owner / Technical Support Manager we got the info that the SDK was not changed for TV Paint 12, but nothing has been done to it neither to ensure the compatibility (meaning not breaking the SDK).
We did lot of tests, recompiling the example SDK plugins from 1999/2000, trying our working plugin for TV Paint 11.7 on 12.0, but there is truly an issue with TV Paint 12.
After lots of investigations, this seems to be on the graphical side, the plugins are all properly detected, when "activating them" from the Windows > Plugins panel they are properly activated, we added code to store plugin state when the program exit and this is properly called, so the C / CPP main logic of the plugin code work well.
We call for help to be able tu support TV Paint 12 and newer.
This is an urgence since it's not possible to buy new licenses for TV Paint 11 / 11.5 from the official store or the vast majority of resellers.
TV Paint is used by lot of studios and artists around the globe, TV Paint supported in multiple pipeline solutions like ours, and this is done via plugin DLL.
Thanks,
Re: [TVPaint12] DLL Plugins don't works
Apart from your issue,
you should be able to still use v11.7 with a tvp new v12.0 license.
ematecki
Post by ematecki »
Hi,
The problem with plugins comes from the switch to 64bits.
At that time, all DWORDs used to pass pointers back and forth between TVPaint and the plugins have been converted to INTPTRs (which is defined according the 32/64bits arch).
It seems that truncating pointers to 32bits worked most of the times on windows with TVP11 even in 64bits, as the MSB 32 bits were all 0s... by sheer luck !
With the new windowing system in TVP12 this isn't the case anymore.
First, check if you have the latest SDK, in file plugdllx.h around line 580 you should have :
INTPTR  TVOpenReq(PIFilter *PiFilter, int width, int height, int x, int y, INTPTR flags, const char *name);
Everywhere you see a DWORD in your plugin's code, check in the .h files if it has to be changed to INTPTR or ULONG32 (all DWORDs in SDK calls have been converted to either INTPTRs or ULONG32s, but you may be using DWORDs in your own non-SDK code, so be careful).
Ben_QuadGroup
ematecki wrote: 16 Dec 2024, 07:26 Hi,
Its seems we have the correct latest SDK version.
We made the changes and recompiled our plugin (dll), this is still not working on TV Paint 12.
To ensure this was not due to another part of our plugin we did the changes (DWORD to INTPTR) and recompiled the SDK example plugin named : Luma Range (that works on TV Paint 11.X) and this is not working either on 12.
We use a Windows 10 (x64) computer, with the cl compiler from Visual Studio 2022.
Here is the link to the CMakeLists.txt and lumarange.def we made to then use
cmake .
and finally call
msbuild LumaRange.sln
https://gist.github.com/BenSouchet/7ef4 ... 50a4d4ebf1
Can you check with a simple plugin like LumaRange (shipped in the SDK examples) that the plugin can work on TVPaint 12.
Thanks
Ben_QuadGroup
Hi,
I raising this subject again, not being able to have plugins in TVPaint prevents all existing pipeline solutions from working, this means that all the studios around the world using PyTVpaint, AYON, OpenPype, QuadPype, etc. cannot interact with TVPaint 12
In addition to studios using pipeline solutions, all the users that want to develop OR use previously purchased plugins for TVPaint 11/11.5/11.7 cannot use it either in TVPaint 12.
If you haven't the time to debug and fix this can you state that officially.
Thanks
Hello Ben,
After your last message we looked deeper in the code because we were surprised that the solution Eric proposed didn't work, because it did work for the guys that created PyTVPaint.
We found out that there was one specific bug that was causing a crash when trying to open a window (which wasn't noticed with PyTVPaint as their plugin doesn't open one).
That bug was fixed a few days before the Christmas break, and will be in v12.0.3 when it releases in early February.
Keep in mind that you will still need to replace all DWORDs with INTPTRs regardless.
Ben_QuadGroup
Hi,
Great news! We will wait for this release and send a message here after testing it.
Thanks
Ben_QuadGroup
Hi,
I just tested version 12.0.3 and the plugins are properly loaded and seems to work, thanks.
