As picture blow shows, whenever I use the dual monitors, the lines will all skewed to one side. I wonder if there's a fix for this. I am using tvpaint 12.
I am using win 11 for reference. wacom cintiq pro 22, 32gb ram
TVpaint 12 line skewing for dual monitors? Topic is solved
- Hironori Takagi
Re: TVpaint 12 line skewing for dual monitors?
There have been previous logs on this issue.
I hope it helps.
https://forum.tvpaint.com/viewtopic.php?p=132400
I hope it helps.
Hello, settings the drawing mode to Wintab and ticking the Subpixel option in the TVPaint Preferences should mitigate the issue.
It should also be completely fixed by the upcoming 12.0.3 patch.
Wow! Hironori Takagi you are a life saver!!! Thanks a million!Hironori Takagi wrote: ↑16 Jan 2025, 05:12 There have been previous logs on this issue.
I hope it helps.
Mark.Mou
- hellofilms
Looking so much to be able to use the pen as wintab and being able to use the right-click option. I can´t fint the Subpixel option to tick in the preferences. Where could it be?
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
On Windows, it is in the General tab of the Preferences panel in TVPaint 11 and in the Drawing section of the Preferences in TVPaint 12.
- hellofilms
I found it, YOu had to choose the wintab option to get that subpixel option. The line is now fine but I can right-click to get that meny up. Will that be changed with the path or will it not be able to work? I think it worked on windows 10.
This issue was already present on Win10 for some tablets, however the upcoming update 12.0.3 should help with this
- hellofilms
Glad to see the fix in 12.0.3. Seems to work perfect so far.
