Dot at start of pencil line
Akira Maynard
Post by Akira Maynard »
I recently encountered an issue with tv paint 11.7.5 on my windows pc using a Cintiq 24 HD. When I use the pencil tool, the start of the line will have a feint dot at the start of the line as if its at 100% pressure. I have tried uninstalling and reinstalling my wacom drivers and it did not seem to work. Is there any solution to this issue?
Screenshot 2025-04-24 230645.png (63.28 KiB) Viewed 6885 times
Akira Maynard
Re: Dot at start of pencil line
I have tried reinstalling and reinstalling both my tablet drivers and TVpaint but the issue persists. The only time there is no issue is when I disable my tour box device/ shortcut remote. I am not sure why but my remote is interfering somehow. Does anyone know a fix?
Screenshot 2025-04-25 021729.png (80.78 KiB) Viewed 6826 times
Hello Akira, did the issue appear overnight? Some setting change in your remote could be conflicting with TVPaint, which TVP shortcuts did you bind it to, please?
kelanhordos
Post by kelanhordos »
I reported on this bug a while ago as well. There is some more info on how to reproduce it in this thread, but it seems to be related to having size having a connection other than pressure, I wonder if that's the case for you? It happens in both 11 and 12 for me for what it's worth.
https://forum.tvpaint.com/viewtopic.php ... il#p136707
Tvpaint 12.0.1 Pro
Thank you Kelan, I will investigate this next week. Sorry for not noticing this earlier.
Akira Maynard
Dean wrote: 25 Apr 2025, 11:19 Hello Akira, did the issue appear overnight? Some setting change in your remote could be conflicting with TVPaint, which TVP shortcuts did you bind it to, please?
This is a list of shortcuts assigned to my remote. None of them are related to pen width or line pressure so I am not sure why they would cause an issue.
Screenshot 2025-04-25 142402.png (63.15 KiB) Viewed 6677 times
Screenshot 2025-04-25 142422.png (73.98 KiB) Viewed 6677 times
Hello, is your TVPaint in Wintab or Ink mode and is Subpixel enabled?
This can be checked in the General tab of the TVPaint Preferences panel.
