[DONE] Paste In Custom Brush Same place as it was Cut
Mads Juul
Post by Mads Juul »
I know I can do this with the Spare.
But I think it would be very Intuitive and Speed Up my workflow if it was possible to make the Custom Brush "Remember" Where It was Cut. So I could "Stampit " Draw it on another image Exactly the same place it was cut.
The I could Use the same tool (Freehand CutBrush + The Custom Brush). To bothe Scale edit rotate parts of a animation drawing and to copy part of a drawing to exactky the same place. inted of now scaling edit with the cutbrush. And copy with the spare. I think that would be very good.
-mads
malcooning
Post by malcooning »
I can't see how it'll work with the CutBrush, but with the selection tool it could. Maybe the selection tool can have a new option in its tool panel:
"copy to a new frame"
and
"copy into the next frame"
In the meantime, why not create a custom button that:
1. Selects freehand
2. and copies selection to Spare
then another button that:
1. copies spare into current frame
needless to say this is key-assignable.
Mads Juul
Post by Mads Juul »
Well It Could only work with the cut brush if I was Changed , when You cut a part out it should remember the pixel(The Center?) where it was cut and the there should be a keybord shortcut to place the the brush at this pixel.
for instance you hold down the kay and the cut brush places at the original position and when pressing with the pen or return the cut out would be placed at the original place.
This is the way it functions in the aniomation software PAP
and its very usefull after my openion.
Im not intereseted in using another tool. because it already functions with the spare. but I want to use the same Intuitive tool -the Cutbrush-. for bith editing ang copying parts of drawing. The same tool = speed = more animation
-mads
