I am still not happy with the "set Pivot issue".
It would be much easier to have a "grab and set Pivot with your mouse" -function, e.g. under "Tools"
Pivot positioning
- Klaus Hoefs
- Klaus Hoefs
If you work with custom brushes and keyframer, the pivot is set first from the brush handle.
When you cut your brush, set the handle interactively. (assign a shortcut to "Brush: Move Handle Corner".)
Then, when you set the keyframer, the pivot will be set at this position.
Use the shortcut again to change the pivot if necessary.
Of course, it won't work if you work in 3D with Zaxis.
edit : once in the keyframer, you can use the "Brush: Move Handle Corner" function again. You don't have to cut your brush again.
Maybe I don't understand your request at 100%.
Manuel
- Klaus Hoefs
it's a wish, for the wishlist, so not in the available features for now (unfortunately).Manuel wrote:Zigotto : I can't do that ??! nothing happend...
hope for the next release, as it shouldn't be so hard to code.
ZigOtto wrote:... would be very useful, imo.
(I think this is an old request, and should be still in the list ...)
