TVPaint & Mirage together?
grumbleboy
Post by grumbleboy »
I've received my new copy of TVPaint, but before I install, I was curious if Mirage and TVPaint can live happily on the same drive. I know that in the "Getting Started" booklet it is recommended to uninstall any previous versions of TVPaint, but I'd like to keep Mirage around for a bit (at least until I finish my current project).
___________________________
Mike Mc
Klaus Hoefs
Re: TVPaint & Mirage together?
Post by Klaus Hoefs »
I have both installed on the same HD with no problem to start one of them.
Although having this, I jumped over to TVP with my current projects and it worked out very well.
__________________
http://www.khoefs.de
no conflict at all between the 2 apps,
but if you have the same dongle for the 2, I don't know if it's possible to run both at the same time,
(not tested here), though, running one after the other should work without any problem . 8)
Klaus Hoefs
Running both with one dongle doesn't work for me.
Running both with two (different) dongle the same.
__________________
grumbleboy
Excellent news--thanks. I'm not looking to run them both at the same time, I just didn't want to completely uninstall Mirage.
Mike Mc
I seem to be able to run both Mirage and TVP off the same dongle, simultaneously... and even save a cutbrush or layer to the clip board in one app and retrieve it from the clipboard in the other without a problem.
idragosani
Post by idragosani »
grumbleboy wrote:I've received my new copy of TVPaint, but before I install, I was curious if Mirage and TVPaint can live happily on the same drive. I know that in the "Getting Started" booklet it is recommended to uninstall any previous versions of TVPaint, but I'd like to keep Mirage around for a bit (at least until I finish my current project).
I've got them both running on the same machine with the same dongle and with no troubles whatsoever. I don't really use Mirage anymore, but just can't bring myself to uninstall it. :-)
Klaus Hoefs wrote:Running both with one dongle doesn't work for me.
weird ... :?
can you tell us more about your config, usb port, soft installation, ...?
did you get at least the splash-screen ? ... or an error message ?
Klaus Hoefs
Raymond, easy to tell:
Mirage has edu-dongle, TVP (from Mirage updated the "commercial" one).
Having both connected to the usb-ports, TVP already running, starting Mirage doesn't recognize the dongle and I get the evalution-pop-up (Register now...; 30 days...).
This just happened on my Dell. I can give it also a try on my Alienware when I'm home (late evening).
I think the different dongles and their codes are in a mess on the Dell.
But anyway I don't worry because I don't work in Mirage anymore. I am only working with TVPpro on my current project.
__________________
so it won't bother you, and that's the good news!
but I always want to know why when things are working differently from one to another computer.
sometimes, there's something interesting to learn in solving issues, even when not essencial. :)
in your case, it seems to be an USB issue, I think, but I may be wrong.
