Salon brushes
- idragosani
Salon brushes
Has anyone gotten the salon brushes custom toolbar (from Mirage) to work in TVPaint? I imported in TVPaint, all of the data files are there, the custom tools are set to use 'H_1.grg', 'H_2.grg', same as in Mirage, but I only get single lines, not the nice hair brushes. All of the data for the brushes are in 'dip' files... what are those? Compiled George scripts?
Re: Salon brushes
never had that set .
I guess it could be a Size setting (or Connection) matter ...?
or does it need a little tweaking in the script ...?
can you post here a screen-grab of your Tool: CustomBrush panel ?
- idragosani
Re: Salon brushes
Everything is at defaults -- in fact, when I click an icon in the Salon brush toolbar, nothing changes at all in the Custom Brushes window
Re: Salon brushes
All the Salon .grg brush scripts have an include command for the nmbrush.grg file in he Element\Include subfolder... do you have that path and .grg file set up too?
- idragosani
Re: Salon brushes
Apparently not! I will look at that and see if it fixes anything.Svengali wrote:All the Salon .grg brush scripts have an include command for the nmbrush.grg file in he Element\Include subfolder... do you have that path and .grg file set up too?
Re: Salon brushes
.dip is the custombrush format.
you also get dip files when you export using deep (in export footage)
