Watercolor Brushes
- malcooning
Watercolor Brushes
Watercolor Brushes
for TVP 9.0 and above
install this pack:
And then take a look at this guide to using the watercolor brushes:
As JPG Or as PDF Enjoy
install this pack:
Asaf | asafagranat.com
Re: Watercolor Brushes
Excellent work !
I wonder what would happen if used with the dirt option of the PPalette. Did anyone try ?
I've said it before: Superb brushes.
Imagine how they can be used in animation.
I will paint all shadows in my film with them, as well as smoke, fire and other effects.
- Sierra Rose
I too appreciate these wonderful brushes. Thanks soooooooooooo much!
WinXP 32bit 10.0.17Pro
The A+B picker doesn't work for me (there is no "BcolfromAcol.grg" is the tvpx format still buggy maybe?)
could you post the grg script seperate?
I wonder where is located your george folder, Peter? (the full path)Tantalus wrote:The A+B picker doesn't work for me (there is no "BcolfromAcol.grg" is the tvpx format still buggy maybe?)
meanwhile, here's the scripts.
- BfromAGrgCmd.rar
- (1.2 KiB) Downloaded 484 times
i wonder too...ZigOtto wrote: I wonder where is located your george folder, Peter? (the full path)
i did a search (*.grg) ...and found 4 george scripts on my machine.
these are their loactions:
- george.jpg (33.29 KiB) Viewed 7989 times
thanks for sending those!ZigOtto wrote: here's the scripts.
hehe... only 4 ? I had 6 George folders, 4 on my main HD, 2 others on a secondary drive.Tantalus wrote:... i did a search (*.grg) ...and found 4 george scripts on my machine.
it seems it's time for you to think of doing a serious cleaning (as I did a week ago or so), I have only 2 folders now.
a task that's inevitably coming one day, specially for us, beta-testers ...
something went wrong with the cleaning?
on startup i get an error message 9b8:
tvp cannot find CDSDK.dll
This corresponds to the Canon Plugin. To fix this, please reinstall the Plugin.
Ex TVPaint Team
Help! Now there are about three different watercolor type downloads. I seem to have the original one installed which looks marvelous, the Hizko brush with four different varieties? Although I haven't made any adjustments to it and am not entirely certain I know how to maximize it's potential... then there is the wetcolor tvpx file ,and another watercolor tvpx, and, a bin/data related download. Is there a final one? Or do they all somehow work together? Any instructions in a single forum entry as to how all of these are supposed to work would be truly helpful for me if someone happens to have the time.
Oh one last question, somewhat off topic, I would like to create a SINGLE FRAME pretty picture using these brushes, possibly destined for print, how can I increase to a very high level resolution in TVP?? It always seems to give me problems...
Marc
Marc
Just create a project with the pixel dimensions you need. For every cm printed size you'll calculate 120 pixels.
- malcooning
The ones posted at the top of this thread are the brushes that's been finalized. These brushes are different to Hisko's brushes as they are based on Custom animated brush, and hisko's based on the TVP pen brush. You can you them in conjunction. It's all about taste and purpose in the end.imihsas wrote:Help! Now there are about three different watercolor type downloads. I seem to have the original one installed which looks marvelous, the Hizko brush with four different varieties? Although I haven't made any adjustments to it and am not entirely certain I know how to maximize it's potential... then there is the wetcolor tvpx file ,and another watercolor tvpx, and, a bin/data related download. Is there a final one? Or do they all somehow work together? Any instructions in a single forum entry as to how all of these are supposed to work would be truly helpful for me if someone happens to have the time.
And someone ( ) already took the time to explain how they work - the jpg placard at the top is the instructions.
The Transparent one gives interesting results with PPalette dirt ! Good idea (i'll post a test picture to show it asap)Fabrice wrote: I wonder what would happen if used with the dirt option of the PPalette. Did anyone try ?
