import photoshop layers
arche75
Post by arche75 »
Hi~
I want to load photoshop layers sequensces like... Please refer to the images.
What should I do? How can it be done?
I have seen george script some time ago. I'm not so sure.
Can you tell me how to solve this problem?
Please tell me... Thank you..
Hervé
Re: import photoshop layers
Post by Hervé »
Hi arche75
Load your PS file, use the "link layers" function in the animator panel and merge all layers.
Hervé ADAM, TVPaint Team
Sewie
Post by Sewie »
I didn't know that was possible. Great option !
arche75
Post by arche75 »
Thanks a lot Hervé
meslin
Post by meslin »
Is there a way to turn a sequence back into a layers?
Probably just using "Split Layer" in the Animator panel, frame by frame. Mirage once had that plugin so I'm sure someone here would know how to make it again. I'd have use for it myself, for instance when working on animatics.
meslin wrote:Is there a way to turn a sequence back into a layers?
yes, create a new button and set Keystroke :
Layer: New Layers From Selected Image
then, if needed, you can add other commands (see pict.) to align all at left.
at first, you have to select your range of frames, then, just hit the button.
Gee, thanks. I must try it soon.
boufertus1
Post by boufertus1 »
Hi! I have the same question as the one initially posted here. But I cannot see how 'merge all layers' will put them as frames in a sequence, as specified above. It just merges them all on one frame. Can you help?
- import that PSD file, now you have a bunch of layers
- select all these layers
- go to Animator Panel > Clip > Link layers (third icon)
- done.
boufertus1
aha i see thanks so much! :)
