import photoshop layers
Hi~
I want to load photoshop layers sequensces like... Please refer to the images.
What should I do? How can it be done?
I have seen george script some time ago. I'm not so sure.
Can you tell me how to solve this problem?
Please tell me... Thank you..
- a2.jpg (9.03 KiB) Viewed 23273 times
- a1.jpg (6.45 KiB) Viewed 23273 times
Re: import photoshop layers
Hi arche75
Load your PS file, use the "link layers" function in the animator panel and merge all layers.
Hervé ADAM, TVPaint Team
I didn't know that was possible. Great option !
Is there a way to turn a sequence back into a layers?
Probably just using "Split Layer" in the Animator panel, frame by frame. Mirage once had that plugin so I'm sure someone here would know how to make it again. I'd have use for it myself, for instance when working on animatics.
yes, create a new button and set Keystroke :meslin wrote:Is there a way to turn a sequence back into a layers?
Layer: New Layers From Selected Image
at first, you have to select your range of frames, then, just hit the button.
- splitSelection.png (5.05 KiB) Viewed 23170 times
Gee, thanks. I must try it soon.
Hi! I have the same question as the one initially posted here. But I cannot see how 'merge all layers' will put them as frames in a sequence, as specified above. It just merges them all on one frame. Can you help?
- import that PSD file, now you have a bunch of layers
- select all these layers
- go to Animator Panel > Clip > Link layers (third icon)
- done.
- done.
aha i see thanks so much!
