Natural Media
Re: Natural Media
Sewie wrote:I've put them in a new panel and posted them anyway.
They are all based on the brushes by Malcooning. "Malc's brush pressure" is excactly the same as his but I only adjusted the pressure settings in the size-profile editor. the other three are my attempts, using an animated custom brush of my own making.
hey hey thanks !! :D
malcooning
Re: Natural Media
Post by malcooning »
Mike,
If you intend to reach natural-media look with your brushes, you need to, well, think like a brush:
1. In the brush that you posted you have scanned (or drew) several frames with elongated lines. Obviously, you wanted these brush strokes to be translated into brush strokes on the screen when put one after the other. But in fact what it creates, is a series of elongated lines, not more. A brush has hairs/fibers/bristles, and when dabbed once on a surface, it creates an area of dots (the ends of the hairs). When pulled across a distance, and given that the approximation between the dots is close enough, these dots will create elongated lines. A clever bristle brush is not made of a single bitmap of a brush stroke (like photoshop has it), nor from a series of bitmaps of brsh strokes (like in your brush) but it is more like a particle system, in which each of the dots (bristle tips) move in progression within the defined area of the brush. In TVP we don't have a particle system, but we can still create a simulation of this system by using frames in the brush. I will post an example when I have more time.
2. Let's assume that your brush can still work nicely, even with its elongated lines. Still, in your brush, the lines were pitched vertically. In this case, your brush will seem 'natural' only in absolutely vertical strokes (top to bottom and vice versa). In any other way, and particularly in absolutely horizontal strokes, you will get the hard edges you referred to, and you will get blocky areas where pressure remains unchanging. If you turn your brush 90 degrees, and assign it's connection to direction , you will get the brush always placed along the length of the elongated lines (see image).
Sewie's brush.jpg (37.75 KiB) Viewed 18033 times
Sewie
Re: Natural Media
Post by Sewie »
That's a real eye opener. Thanks, Asaf !
Re: Natural Media
Ahaaa!
Had to test this immediately. Did a cycle of 12 drawings with some more solid strokes moving in circles (but keep direction) and some lighter ones to fill the gaps. Fiddled with the tool settings until it looked right. Had to shorten the lines in order to avoid that "star effect" at the end of strokes. It is a bit slow, thankx to a step setting of 1,5 %. But I'm sure others will improve the idea soon.
pinsel1.tvpx
(148 KiB) Downloaded 1188 times
Have fun!
Sewie
Re: Natural Media
Post by Sewie »
Did you connect the angle's direction settings to "direction" ? Can you perhaps post a screengrab so we can see in what panel it's done ?
Sewie
Re: Natural Media
Post by Sewie »
With the setting's like this, your brush makes a pretty convincing drybrush, Slowtiger!
malcooning
Re: Natural Media
simply type "90" in the 'Angle' box (in the panel that you posted yourself just above), it will fix your brush at that angle, and the 'direction' will be set following this.
Sewie
Re: Natural Media
Post by Sewie »
Ah, thanks.
